Hello, look at this file. In the view "Fundamentplan" I got some annotation lines wich are hidden, but I have not hide them and I can`t unhide them. You can see them if you turn on the "Reveal Hidden Elements". What is wrong here?
I`ve tried to reduce the filesize but it`s still to big to attach here.
Eirik.
Solved by Joe.Charpentier. Go to Solution.
Solved by CoreyDaun. Go to Solution.
I've received your file via email. Looking at the View that you mentioned, I see that "HELP" you drew in Detail Lines that become visible in Reveal Hidden Elements mode. They are hidden simply because the "Lines" Category is turned off. Even though these lines are Annotation Lines, their visibility is controlled by the "Lines" Category under the Model Categories tab, in Visibility/Graphics Overrides.
If you want to "attach" a Revit file to a post, the best solution is to put a link in your post to a file uploaded to Dropbox or an A360 account.
Both services (even at the free level) should have plenty of space for a Revit file.
Joe
Ah, thanks, I was looking at "annotation categories" in visibility/graphics to see if I could find something there. Great.
