For some reason when I create a new view, I am unable to edit the visibility/graphics, or make any changes to scale, detail level, etc. It's probably an easy fix, but I'm stumped.
Solved by CoreyDaun. Go to Solution.
Assuming that you're using Revit MEP 2013 or 2014, the issue is that Views are linked to View Templates which, in turn, are controlling the View Filters. If you want to change the View Filters for this View, you can either create a new View Template and link the View to it, or set the View's Template to "<None>". You can set a View's Template under the View's Properties.
