CADMOMMA , in her **This is SO Not in the Book!** class at Autodesk University tells us....
ADJUST the TEMPORARY DIMENSION FONT SIZE (for RAC)
Open the Revit.ini file in Notepad. It can be found here:
C:\Program Files\Revit Architecture 2009\Program\Revit.ini
Add the following line:
[Graphics]
TempDimFontSizeInPoints=N
The value of “N” has a default of “8” so you need to increase this value. A good point to begin is
to double the size. It is best to do a search for this text to see if it has already been changed in
the ini file.
.... and so many other great tricks....
Dan
