I am using Revit 2014 but would like to complete the Revit MEP 2010 Imperial Tutorial. Does anyone know where I can obtain the MEP 2010 training files for downloading?
Solved by SteveKStafford. Go to Solution.
Hello, and welcome to the Discussion Groups!
Sorry for the delay of response. I was unable to find the Revit MEP 2010 files for download on Autodesk.com, but perhaps a Google search may find another source?
Is there a particular reason that you are seeking the Revit MEP 2010 tutorials? If you are using Revit 2014, a lot has changed since then, and some of the points in those old tutorials may be a bit different or flat out wrong, now.
Hello Corey,
I have a hardcopy of the Revit MEP 2010 Imperial Tutorial and would like the training files so that I can do this tutorial. I also have an Autodesk Training Guide (Sybex) that also comes with training files. I have noted that newer Revit training is usually video tutorials, I prefer PDF tutorials. It is strange that no one in the Autodesk community knows where one can find these useful MEP 2010 training files for newbies. I have also tried searching for them on Google without success.
I have a copy of the 2010 MEP tutorial dataset POSTED HERE. I'm not sure it is the complete dataset because of the way the folders are numbered but it may be just based on chapters in the tutorial.
Steve Stafford
