Model keeps on regenerating even when doing the simpliest things like deleteing and element to drawning a pipe. It just seems to take for ever to do anything while working in a callaboration project. Someone said it might be my graphics card. Any help would be nice, thanks.
Over the past two days my Revit file has started regenerating with every command.
eg. placing a wall reveal, placing a window, deleting a window. This has made working nearly impossible, as every command takes 45secs-1minute to complete.
I have purged my model, made sure 'enable analytical model' in properties is turned off, made a new central file, removed cad and revit links and went through the warning list but to no avail.
I had our IT guys clean my computer but the problem persists. I also had a colleague open the file on her computer to test it out. She had the same slow/regenerating issues! Something has gone wrong in the file somewhere? But where?
I haven't been using tiled views. I have also deleted unnecessary views in the model and purged the model.
I took an older local file and tested it to make sure the regenerating wasn't happening in this file. Then I began re-doing the work I had done. Eventually the regenerating and slowness started again in this file. I am currently adding windows, wall reaveals and wall openings to concept walls in a model. Nothing to tricky, but very, very slow. Too slow to work in and not fun when you have an approaching deadline.
Please help!
Always difficult to pinpoint what is causing this. Some causes I have experienced that slowed down Revit.
-Hardware. Not sufficent for the project size (memory, harddisk, processor)
-Network issues. 'damaged' network cards or other colleagues with slow network cards (100mb instead of 1gb).
-Too many things open at the same time. Within Revit too many views open (e.g large schedules). Also too many other software active.
-Too many highly detailed families. Or 'super'families (i.e. a single family with options for all kinds of situations)
-Families containing foreign file formats (e.g. 3d dwg, sat, skp)
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks louis,
My machine is very powerful and has delt with biigger and more complex files than this.
I have opened other files in the same file location and the issue isn't happening in any other file. I don't think it is a network problem either.
I have no other software open and i have working in one view. i have also deleted all the views i don't need in the model.
The model at present is basic concept walls and concept floors (no detail/materials), and no familes other than standard windows and doors. I have groups in the model, but I have also worked in another file with more groups than this, with no issues.
Really stumped!
I have removed all my linked models and files.
I have reduced the detail to course and hidden line. the model is just concept walls and floors at present so it doesnt have much detail in it anyway.
I have turned off my hardware acceleration in the options.
My computer is fairly new and a great machine. I don't think I need to update my video card driver, but I will keep it in mind.
It looks like I am going to have to remake the entire file. Devastating!
Thank you for your suggestions!
So was there any movement on this issue? Any new insights?
I have a similar issue. We replaced the PC with a much more powerful machine. Same issue. We had another user on another machine work on the same model with no issues. We had user 1 log into user 2's machine and the issue followed the user. This indicates the issue is with the user account and not the machine. What i don't know/understand, is what options I have that are user account specific? Seems any account settings would be permission related rather than performance. Any suggestions are greatly appreciated.
We had an issue with systems, where the regenerating process was stooping us from making edits, it Threw naming errors. It was not the same on all pcs. We finally got a handle on it by resting revit on all pcs to factory default. More in this link:
I experienced this within many years as a user of Revit and AutoCAD. Always wth a dead end. The only solution is to open up a new file then copy the model elements over and save that file as the new file. Problem disappears. So my conclusion always been is the ghost within that is glitching it.
