Hello All,
I am working with large diameter piping (48"+). I am new to Revit and don't know if there are flanged reducers and tees to use for pipe routing. DI or GI material preferred.
Steve
Solved by abulla. Go to Solution.
Flanged fittings should be built into your library under Pipe->Fittings. You may have to set up a new pipe type that uses flanged fittings if one isn't built in. Load the flanged fittings you want to use, then change the Routing Preferences for the pipe type to the fittings you loaded.
Dear Sir:
we are manufacturer for the flange, steel elbow , steel tee , steel reducer since 1982 , if you have any need ,feel free to contact me .
Using the latest that technology has to offer, we supply a wide range of industrial forged flanges and fittings including slip-on flanges, socket weld flanges, blind flanges and many more that find their applications in the petrochemical, automobile, textile, pharmaceutical industries.
Our service:
if any need ,feel free to contact me .
Best Regards!
Lisa Li
Sales Manager
Mb:+86 15230726554 Skype:gee8101
Tel:+86 317 6853 733 Msn: gee8101@hotmailcom
Fax: + 86 317 6853 733 E-mail: lisali@geepipe.cc
Whatsapp:+86 152 3072 6554
www.geepipe.cc www.haihao.com
