Revit MEP Forum
How to create a variable length LED Luminaire (lighting fixture)
6 REPLIES 6
3816 Views, 6 Replies
 I was trying to make a variable length luminaire that could calculate the load automatically.
The problems I came across were dimensions & watts could not be calculated together, or the message
"Instance Parameters can't be used in Type Parameter formulas.
Type Parameter "Length" is driven by Instance Parameter(s): "Feet"."
First step is to determine the Load per foot. (15W as example)
Family parameter/Type
  • Name: Apparent Load
  • Discipline: Electrical
  • Type of Parameter: Wattage
  • Group parameter under: Electrical Loads
  • Value: 15VA
Next step is to determine the length. (4 foot typical length)
Family parameter/Instance
  • Name: Feet
  • Discipline: Common
  • Type of Parameter: Integer
  • Group parameter under: Dimensions
  • Value:4
  • Name: Length
  • Type of Parameter: Length
  • Value: Feet * 304.8mm (or 1' for imperial)
  • Name: Calculated Load
  • Value: Feet * Apparent Load
Now for the Connector Element
Apparent Load should be Associated to Calculated Load
Label the Length Dimension
This works for a straight line LED luminaire.
For a circle with variable radius & perimeter try this:
Add
  • Name: Radius
  • Type of Parameter: length
  • Value: 304.8mm
  • Name: Angle
  • Type of Parameter: Angle
  • Value: 45
Replace
  • Name: Length
  • Value: Angle / 360° * 2 * 3.14 * Radius
  • Value: Length/1000mm * Apparent Load
 Label the Angle & Radius Dimension
6 REPLIES 6
CoreyDaun
  • Name: Feet
  • Value:4
  • Name: Length
That error would be occurring because  the parameter "Length", although intended to be an Instance Parameter, is defined as a Type Parameter in the Family.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
CoreyDaun
@Anonymous wrote:
...The problems I came across were dimensions & watts could not be calculated together...
You can create a formula to directly associate the load with actual length - You just have to make the length unitless:
Total Watts = Watts per Foot * ( Length / 1' - 0" )
Attached is a family basically demonstrates my method, in case it's of any help. (Revit 2012)
in reply to: CoreyDaun
Those were just sample errors I came across while trying to create the luminaire.
This is a "How to thread", not a "Please help me" thread.
I remember reading a post with this type of problem, but could not find it again once I solved it.
csamaniego123
How do you manage to edit the length if you set it as instance in order to use it in a formula? Also, how is this lenght is not working with Label. And why i cant modify Length parameter in the Family Type.
So many questions.
Thanks in advance
in reply to: csamaniego123
CADastrophe's version does not use an integer variable to control the length.  It does allow you to stretch it manually.  You can add an Integer Parameter as shown.
Most fixtures are set to a "per inch" or "per foot" value.  If you use Shared Parameters, you can get your Tags to read the values.
Small correction:
Length Formula should be ( WperINCH * 1")
Forma Design Contest
