I would like to edit Revit default formula for pipe friction factor,
where can I edit it?
The following link shows Revit's formula:
which is
friction factor (f) = (1 / (2 * log10 (3.7*e))) ^ 2
thanks!
Solved by Martin__Schmid. Go to Solution.
I don't think that you can edit Revit's calculation formulas, they are hard-coded. Submit your issue with Autodesk Feedback/Support and provide reasons why you wish to edit this formula.
The current formula is a simplified, factorable version of the Colebrook equation. It is presently not possible to edit this formula. What would you expect the formula to be?
Martin:
Thanks for your reply.
Your are right, according to Colebrook equation
1/√f = -2log(2.51/Re/√f+ε/3.7D)
In Revit, it simplifies to
1/√f = 2log(3.7*D/ε)
My formula expressd Colebrook in a expanded form
1/√f =1.74-2log(18.7/Re√f+2ε/D)
which has a more accurate result
So I would like to edit Revit's forumla which leads a more accurate result.
Thanks anyway.
Hope Revit can allow edit built in equations in the future.
One challenge with the stnadard Colebrook formula is that it is inherently recursive, which computing may be detrimenal to performance. Would the solution to this as presented in: http://math.unice.fr/~didierc/DidPublis/ICR_2009.pdf be an acceptable method to solve?
Thanks Martin. It really helps to get a closer answer.
Hope Revit can intergrate a better customize computation method to suit engineers.
Dear,
I've made a lot of pipedrop calculations with REVIT but the answers seems to be incorrect for turbulent flow. I think the friction factor calculation is much to far simplified. The answer seems to be a factor 3 incorrect with other computer calculations or manufacture tables.
I've made two caculations for REVIT and 1 calculation for a alternative friction factor formulas (see the pdf attached). This formula is commonly used in piping software. I really hope that I do something incorrect.
I'll hope you can help me.
Greatings,
Bastiaan
Hello Bastiaan-
I want to make sure I understand the full extent of your scenario.
I'm trying to replicate your case, and am not quite sure how you got the Reynolds value of 6391.
From the document, I am getting:
R = pVL / u
p = exactly 983 kg/m^3
v= exactly 0.215 m/s
L = exactly 0.012 m
u = exactly 4.0e-4 Pa*s
R = 6340
If I use the un-rounded value for v from Revit (0.215142), I get :
R = 6345
How did you arrive at
R=6391
Thanks for any clarification you can provide.
Can you please help me to change the calculation method of the pipe settings calculation??
In the new version (revit 2014) the method of the "duct" calculation is correct but for "pipe" is still the wrong simplified Colebrook equation used.
How can I change this pipe calculation methode to be the same as the "duct"?
in your pdf previously, you showed using the Swamee-Jian equation
Currently, Revit computes the Duct friction factor using the Altshul-Tsal method.
Would you prefer Swamee-Jian for both, or Altshul-Tsal?
Both the formula's have almost the same answer for my working field. It's also okay to use the Altshul-Tsal formula. Is it easy to use this one for "pipe" also?
Dear Martin,
It's really disappointing that I get nog response from Autodesk. My subscription helpdesk tels me that I'll have to wait for your solution but I don't get any response on this forum.
I really got a big problem because my model is worthless because the friction factor formula for pipe is incorrect. Can you please give me the option to use the "duct calculation" methode als for the "pipe calculation" in Revit 2014. The solution seams very nearby and this makes it even more frustrating.
Or can you tell me how to adjust the formula?
Waiting for your response.
Greatings,
Bastiaan
Hi David
A workaround would be to apply your own "Constant Factor" to your results.
Do a few calculations and notice a pattern. Use your engineering skills to figure out what that constant is and apply
it to your results. In other words develope your own formula.
Cool stuff uh?
