UNABLE TO COMPLETE CABLE TRAY LAYOUT, I CANNOT FIND THE FAMILY FOR THE CABLE TRAY FITTINGS
WHERE CAN I FIND IT AND LOAD INTO MY REVIT MEP
Im assuming you have tried to load the fitting families from the cable tray folder from the default library?
Insert-->Load family-->the installed loaction of RME 2012-->Libraries-->Imperial/Metric-->cable tray
Are you missing the library?
Is it just the cable tray fittings or did none of the category families populate in their respected folders?
The only thing you can do is reinstall/repair. You cannot just grab the necessary files from the install disk. Can you get them from a co-worker?
