I'm having an issue where I have sensors and a sensore line (a symbol and a detail line) on my plans but when I create a viewport of the plan on the sheet, the annotation doesn't appear. I've checked the V/G settings and everything appears to be on and the annotation is visible if I go to the plan view. Has anybody solved this before?
Solved by CoreyDaun. Go to Solution.
The attached View should look exactly the same on the Sheet as is does in the View. Here, it's happened before where someone simply attached the wrong View. Go to your Project Browser, and scroll down to the Sheet View. Click on Expand (the plus symbol) next to it to reveal the list of attached Views. Open that View from here to ensure that it is indeed the correct View.
