I would like a right click feature when hovering over a link to make the link non-selectable. Just like how AutoCAD works with Excel files linked in. Filtering/pinning the links are good but non-selectable would be great!
I absolutely agree with this, as well as most users would, I imagine.
Discussed in this post is a work-around method of achieving this. However, this is NOT a solution, nor is it flawless.
Bump!
Can't believe this is still not implemented.
Every person I've ever talked to working in MEP notes this as a significant annoyance. After I set up arch/structural linked models and pin them, I NEVER want to select them again.
Mis-clicks and the resulting 5-10 seconds of lost time happens every couple of minutes. That is a big loss of efficiency. Seems like a very easy fix to just add the unselectable option.
Everyone who uses REVIT, will ever want to use REVIT & those who are not even born yet want this feature. I cannot beleive how many times I cannot even select a duct or put a diffuser in because for some reason the link is preventing this! Please, Please implement this. Make it unselectable, if I want to select it I will open up the Link itself & do what I have to do then reload it back in.
