• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Member
    JimMorel2946
    Accepted Solution
    A SImple Question on modeling drafting & the linked architectural file
    306 Views, 7 Replies
    10-19-2011 05:38 PM
    I am a realtively new user &  enjoy using Revit MEP 2012 for design.  My question is:   Is there any way of locking or "freezing" the architectural Revit link file in my MEP Revit  file so it can never be selected , highlighted etc .as I model & manipulate my piping.
     I model extensive plumbing piping in the architectural linked file background & have a hard time not also selecting the architectural background.   I do use the filter which helps greatly but it can be tedious & extra steps involved.
    There must be a better way that I haven't discovered yet  !  Any feedback would be greatly appreciated.
    Jim Morel
    JMC
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: A SImple Question on modeling drafting & the linked architectural file
    10-20-2011 02:22 AM in reply to: JimMorel2946
    You could use design options and place the link on a different design option to the piping
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    Distinguished Contributor
    thombrady
    10-25-2011 12:51 PM in reply to: julianjameson8403
    This would be something very nice!! I can't recall how many times I am trying to tag a duct & it wants to keep tagging the ceiling. I then have to shut off the link, something simple but another step that should be avoided.It is nice to pin the Links but it would be great if they could stay in the background. I thought this was REVIT MEP not Arch. Sorry to go on a rant on your post.
    Member
    JimMorel2946
    10-25-2011 01:25 PM in reply to: julianjameson8403
    Thank you very very much.  It works.
     It may seem a small thing but it is a huge help in our MEP drafting/modeling.  I've read the Design Option several times & really don't understand it's full potential at all  but after several tries implementing it is simple like you say.
    Set up a new design option.
    Go back to model.
    Select architect model(or any other link or item)
    Then go to the Add Set button & seletc/add architect model to the new design option just created
    In the main model  having the exclude button checked makes the architect model just a background ( not selectable ).  Huge help in MEP modeling.
    Thanks again.
    Distinguished Mentor
    10-25-2011 08:30 PM in reply to: JimMorel2946
    This has been a wish wishlist item of mine for years. it's locked. I shouldn't be able to do anything period...it's locked. Really we what does locked mean.
    “Anything worth doing is worth doing poorly, until you can learn to do it well.”
    Valued Contributor
    Happyunited123
    10-27-2011 09:53 AM in reply to: JimMorel2946
    Where is this design option you talk about?
    carriehall42
    10-27-2011 12:21 PM in reply to: Happyunited123
    Design options is under the manage tab, next to project location.
    10-27-2011 12:55 PM in reply to: carriehall42
    The only issue with the design option way is loss of functionality with grids ( if you copy monitor).
