Is there a way to get roof beams/windows/etc to show as dash-dot in floor plan without having to make changes in every family or for every new object?
Thanks!
Do you want to see an overhead object on a lower plan? ...if so :
Constantin Stroescu
Well, that is one way of doing it of course. But lets say I have 200 beams and 50 windows, and add/remove objects along the way.... I think there should be a way to say "I want this type to show as dash-dot when above cut plane but not on the floor plan above". Seems like a pretty common thing, to want to show in a plan. The way you under VV can chose to show "above risers" for stairs.
