Is there a place that I can download the 2015 updates?
Thank you for the help.
Solved by Tony_Michniewicz. Go to Solution.
The only downloads for Revit 2015 that I could find tonight at http://knowledge.autodesk.com/ were Language Packs.
A Google search turned up this:
The Autodesk Application Manager is capable of accessing the update.
This post contains links for Update Release 2, which includes security updates as well as the updates in Update Release 1.
@Anonymous wrote:The only downloads for Revit 2015 that I could find tonight at http://knowledge.autodesk.com/ were Language Packs.
Thanks David, I found that discussion with the download links and got the updates from there.
Autodesk Application Manager is fine for people who have admin rights to install. I like to use Group Policies to install the updates to all computers, instead of getting pinged by everyone that they have an update.
While messing with Autodesk Application Manager I noticed it downloads copies of the installs to your "C:\users\username\Documents\Autodesk Application Manager", I can pull them from there and use GP to install to the rest of the company. You can also change this folder if you like. Pretty neat.
Thanks again
The following links can be used to download the latest updates for Revit 2015 (in this case the security update release, aka UR2):
http://download.autodesk.com/SWDLDDLM/Updates/2015/RVT/Autodesk_Revit_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RAC/Autodesk_Revit_Architecture_2015-x64_Update2....
http://download.autodesk.com/SWDLDDLM/Updates/2015/RME/Autodesk_Revit_MEP_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RST/Autodesk_Revit_Structure_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RLT/x64/Autodesk_Revit_LT_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RLT/x86/Autodesk_Revit_LT_2015-x86_Update2.exe
Tony Michniewicz
Autodesk Revit QA
Thanks Tony - Are these going to ever be posted like they were with older versions under the knowledge base and downloads?
I got what I needed from Autodesk Application Manager and other discussions so I should be a happy camper until the next update. 🙂
Thanks again
I don't have an exact date for their availability but the Autodesk knowledge base will include separate pages for each of these downloads. Each of these pages will include a link to the update as well as the associated readme and enhancement document.
Glad to hear that you're a happy camper at this point!!
Tony Michniewicz
Autodesk Revit QA
Thanks again
I agree 100%. Most of my users do not have administrative rights and I am not going to log into every machine to do the installations. I am more than happy to let the IT wizards take care of deploying it over the network. But I would like to have the update installation files for future record/use, along with the readme so I can see what it is supposed to fix and if there are any special instructions or other information I should know, so I would like to see the "knowledge" pages updated more quickly after an update is released.
Thanks for the heads up on the fact that the file does get saved locally by the Autodesk Application Manager. I was not aware of that; turns out I have quite a collection of files there.
