Updates - Revit Architecture 2013
4 REPLIES 4
1628 Views, 4 Replies
Hi! I have a computer with Revit Architecture 2013 on it. When I check for updates I have one available. When I click to get the update I get an internet explorer screen with a yellow bar near the bottom that says the website was blocked, I click allow but then nothing happens. Is there a way to get around this? Revit has service pack or update release 2 installed on it. I am trying to get release number three.
Thanks!
Rob
Tags (1)
4 REPLIES 4
David_W_Koch
Assuming you have Revit Architecture (and not Revit "one box"), you can download Update 3 from the Autodesk website. http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
in reply to: David_W_Koch
Dave,
Hi! Thanks for the quick reply. Its a single seat of Revit Architecture 2013. Not part of a suite or the Revit that has MEP & Structure with it. Will the link you provided work for my software? Its also the 64 bit version.
Thanks!
Rob
edwin.prakoso
Try this one: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21890399&linkID=9273944
Cheers,
Edwin Prakoso
in reply to: edwin.prakoso
Edwin,
Thanks! This worked perfect. I appreciate all of the help.
Take care,
Rob
Forma Design Contest
