If the section line passes through any portion of the geometry that make up
the door family whether its 3D or 2D, it will display. You must be using
the doors with the adjustable swing, so that the solid that makes up the
door panel can actually appear open in a 3D view. Your section line cuts
through the 2D projection line on the ground that symbolizes the door swing
(the arc) and therefore is displaying the door itself in your views.
You could turn off door panels for this section under Visibility, but this
will turn off all door panels. or you could load a different door.
You know what, taking a closer look, it appears that the door *behind* your
section view is showing through. Its hard to tell, but it appears that you
have a line coming out from the door behind, that your section line just
crosses over. I think this might be the source of your gray boxes.
HTH,
Scott
"Rafaele" wrote in message
news:40b8d089_3@newsprd01...
> When I make a section, some gray "shades" appear in the section view
though
> the section plane doesn't touch that doors.
> How can you eliminate that gray doors' shade in the section view?
> Thanks
