The shape is a sweep of a curve on another curve. It is not a revolve.
(1) Not able to sweep
(2) Only need the outer shell surface if I do a sweep with a closed curve
Solved by Alfredo_Medina. Go to Solution.
Have you seen the May 2012 issue of Augi World?
There is an article there, on page 10, about hypars and other similar forms, written by a friend of yours. 🙂
