Is there any option to create a split with gap in Elevation Level as section. We have attached a snap for your reference.
Thanks in advance!
Solved by constantin.stroescu. Go to Solution.
Use a Croped View and click on the border's small icon : Vertical View Break...
https://chronicle.autodesk.com/main/details/78e81d20-b718-4e8a-8853-e64b30c404c7
Constantin Stroescu
Thanks for your reply. Mainly we want to hide Elevation Level line, the portion where we break crop region.
In such a case , I use Scope Box and arange on sheet:
Constantin Stroescu
Thanks a lot for your clarification.
So for now we can't do this with a single view. If we need then go with scope box option with placing 2 views with manual adjustment in a sheet.
If this features will be incorporated in next release then it may be helpful to all of us
