I am not sure what a gable roof with sprockets is? Google did not help me much either. Could you post an image of what you are trying to do and prehaps someone can offer a way to accomplish it.
Did he mean to write "crickets"?
http://en.wikipedia.org/wiki/Cricket_%28roofing%29
Thank you for your reply. I did not mean crickets. I meant sprockets. It's not uncommon on Victorian Houses. Please see the attached. I live outside Philadelphia and there are some mansions with this detail.
There are probably several ways to do this, but I am thinking you will have to create two roofs. Create the base roof (sprockets) at the slope you want. create the cutoff level where you want it to stop then create the main roof with it's slope. http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/0325-Build_th325/0327-Architec32... Yuo can also probably do it as an extrusion. Let us know how it goes. Good luck!
Craig's idea with 2 roof elements will probably do the trick.
Another option would be to create the main roof and then create the "sprockets" with an in-place family. That is how I created this example. It is pretty crude, but with an exact situation I could get it to look the way it is suppoed to.
