For some time Revit has a had a "roads' Catagory. Since Revit 9.1 I recall. However from research and asking many there is no way to creat a road and isn't a way to make a inplace family that would be assigned to the Roads Catagory. Can some one shead some light on why we have a catagory that appears to serve no function.
Solved by Alfredo_Medina. Go to Solution.
You're correct. Last time I read about this, somebody said that at some point the "Road" category was created "for future use", but then it was forgotten, but still remains there...
