Could anyone help me with trying to create a curved roof? I want it to be flat apart from where the sloped walls are, the sloped walls are in-place models.
I thought I could do it using swept blend but i'm a little unsure of how to approach it.
I must warn you I'm a bit of a rookie with Revit.
Any help is appreciated.
Create a flat roof by footprint method.
Then, along the sloping walls, use "edit points" to conform the roof to the wall profile.
cheers
