You received the following error message when starting Revit® Architecture or
when opening an RVT file or specific view:
This error may occur if your graphics card is not able to be used for
hardware acceleration within Revit-based products.
To prevent this error from occurring, disable hardware acceleration. Follow
these steps:
In Revit 2009 Products
In Revit 2010 Products
If you are unable to start Revit as a result of this error message, you can
disable hardware acceleration by following these steps:
UseGraphicsHardware="
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Ivo" wrote in mes
Has
someone else experienced this strange behaviour, where drawing plane turns to
black and you get unhandled exception. The error is hard to reproduce (there
are no exact steps), I've noticed that it happens, while Orbiting or Panning
in edit mode (Curtain Wall or Mass Edit). Attached is the error messages,
after that I get "fatal error" message and it tells, that the application will
be terminated.
Were you able to resolve that problem on Revit Architecture 2010 with what the other suggested? I'm having the same exact problems on mine ever since I downloaded and activated it last month, and I need help with this too. Thank you.
I had a similar issue - I ran Revit 2010 as administrator - all my issues went away.
Hope this helps someone.
