hello, i just started working with Revit Architecture 2013 and im doing this tutorial for a basig design but at one point it says go to Massing & Site tab in the ribbon, and it's just not there? i have a sort of test on working with Revit tomorrow so i kinda need it really bad right now
thanks, Jelmer
Solved by constantin.stroescu. Go to Solution.
Application Menu (big R)> Options > User Interface>Configure>Tools and analyses:>check Massing and Site tab and tools...OK
this is an improvement of Revit 2013...
Constantin Stroescu
are you working in Revit 2012 or another previous version? ...This Option was introduced in Revit 2013...
Constantin Stroescu
Thanks Constantin Stroescu, I have been searching for the rest of the tabs for two hours. The only one that was displayed was the Architecture tab, I needed access to the Structure tab. THANK YOU very much Sir!!
@Anonymous
Revit LT does not offer the Massing Tool/Environment ...it has only a Site tool
