It's still not possible.
If you mean to draw a split section with a 90 degree kink:
Draw a Section,
Select it,
Then in the ribbon under Modify / Views, click the "Split Section" button.
the cursor will show a knife. click on the section where you want to make the cut and drag the section to make the kinked split.
still not possible.
Still unable to make a cranked section in Revit 24 it seems.
Revit 25's out now... still no?
Autodesk... too much to ask?
