Hello All,
I am developing my sheets and I noticed that hidden lines are not showing on my pipe penetrations. My discipline is set to Coordination. The walls are part of a linked revit model. Is there a setting I need to turn on? Thanks in advance. See attached.
Steve
Solved by CoreyDaun. Go to Solution.
MEP Hidden Lines are a function exclusive to the Mechanical, Plumbing, and Electrical Disciplines, and they will not display in Architectural or Coordination Views. I see you are trying to represent the portion of the MEP element that is hidden behind the Wall, but since these elements belong to different disciplines, this is not really possible. MEP Hidden Lines only work between MEP elements and the 'Show Hidden Lines' tool only works with Architectural elements, so neither would work here. I believe your only option is to represent it with Detail Lines.
Hi, is possible in 2017 to show hidden lines off pipes in arhitectural discipline? We also need center off lines in normal view not only in fine view, we must use combinations in our drawing.
Do you know is possible to have in Arhitectural discipline in VG not vissible mechanical and pipes,
then go to one view and you turn on hiden elements, I see mechanical and pipes element which are hiden-frozen and I want to just select on pipe to be ovveride by element to see it in this view?
We have a lot off time that we need electicity pipes, for roof pipes,.... to see in constructions view.
Best regard,
Katarina
