But it WILL work......If you change the Layer Settings by clicking the
Options button in the Export Dialog to "All properties BYLAYER, new layers
for overrides" then you will get "EXST" and "DEMO" as part of the layer
names for those objects that are on those phases in the DWG.
wrote in message news:6009407@discussion.autodesk.com...
You can't. The export does not maintain the phasing per say. You would have
to create an existing view to export, export it, change the layer in
AutoCAD, and then export just the demo, chage it in AutoCAD, then insert one
into another, and so on, until all of the phases have been accounted for.
Revit's phasing does not have any corresponding item in basic AutoCAD to
correspond to it, other than additional layers. Revit accomplishes this with
a material over-ride. That is why it does not translate phasing into layers,
because you could have 12 phases (heaven help me) and then you'd need three
wall layers for each phase.
Scott Womack AIA
