Hi all,
I am completely new to Revit and am trying to model Curtain walls.
Apparently i am supposed to have 3 options of Curtain Walls according to the help in Revit Arch 2014......i have attached a snip of this (see CW 1), but i only have 2 options in my list (CW 2). Why is mine missing...i need this one 😞
Cheers
Cad_Cow
Hi cad_cow,
You can check to see if you have the project template file below, if not, I simplified it and put it in attachment.
C:\ProgramData\Autodesk\RVT 2014\Templates\US Metric\DefaultMetric.rte
You can create a new project with this template file, then use "Transfer Project Standards" function to transfer "Curtain Wall Types" from this project to your current project. See "curtainwall.JPG".
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Cad_Cow
You can simply duplicate and modify one of your existing types of curtain wall to whatever apperance you want. The "default" ones you get in the templates are just curtain walls with different pre-set settings in them.
In the attached image, the settings i have input give you this kind of output. A big factor here is the "Layout" option you select, each one does something different. Practice with them to see the kinds of output you get.
Hope this helps
