http://screencast.com/t/BiMiAx20b
I am having trouble constructing a concrete stairs between two levels with a winder at both end. Upon creating the precast stairs, Revit will not allow me to complete the winders in concrete. I have tried sketch mode to draw the stairs but all I am able to do is create a timber stairs with a curved winder.
Can anyone assist me in how to construct a concrete stairway with winders at both end.
Would it be possible to create a couple more Levels ( for creating small individual winder stairs at Lower and Upper Levels )
and build the starirs with 3 individual winder stairs?
Level 1 Bottom
Level 1 Winder ( with Landing at specific height above Level 1)
Level 2 Top
Level 2 Winder ( with Landing at soecific height below Level 2)
Run 1 from Level 1 up to Levl 1 Winder
Run 2 from Level 2 down to Level 2 Winder
I have not tried this in Revit, but it seems possible in theory.
I appreciate you getting back to me on this issue. Firstly, I am new to Revit Architecture, and I am trying to understand its operation. Please bear with me.
I am having trouble grasping your solution to construction of the stairs with winder. Can you please explain more in detail how to achieved this.
