Beyond lines displaying for walls of floor below and cannot get rid of - view range is set with bottom offset at floor level, cannot override beyond line style and nothing else I can find to turn them off. Its walls, door openings (not symbolic lines etc.
Solved by Alfredo_Medina. Go to Solution.
Check the Underlay property of the floor plan view. Is it set to show the floor below?
@timandjo wrote:Thanks - yes thats what it was.
Good. Then please mark the Solution.
