Hi, Maybe you could help me with this problem. Im Trying to create New Area Plans but i cannot see my site plan in the box.
What should i do?
Please see attached.
Thank you.
Solved by constantin.stroescu. Go to Solution.
You have Area options only for the Levels.
Open an elevation view , you have here all the named Levels. Open : Area > Area Plan - in New Area Plan window you will see in the list all your Levels names.....see what it is written there : Select Levels.. Site is View ...not quite a Level. But you can make a new Level high enough and with an adequate range ...
Constantin Stroescu
Thank you,
