I have installed Student Version of Revit 2013 and the associated Extension pack. Installation and basic operation all OK.
As per the screen shot attached, the Extensions ->Modelling->Wood Framing Walls option exists and works OK.
I was also expecting to see in the Extensions ->Modelling 'Rafter Framing and 'Roof Trusses' options.
Should these have been installed with the Extensions pack? Are they available elsewhere?
Are these only available under 'Subscription' ?
Is this avalable to the Student users?
Many thanks
John
Solved by edwin.prakoso. Go to Solution.
Hi John,
I'm sorry that I see this thread late.
Those tools are not included in that extension.
You need 'Timber Roof Framing Extensions for Revit 2013' to get rafter framing and roof trusses tools.
Cheers,
Edwin Prakoso
Will these extensions work with Revit LT 2013?
Can the Wood Framing Extension generate a schedule or Quantity Take-Off?
Jerry
