Here are a couple of possibilities
1) The dwg in inserted above the Cut Plane or below the Bottom plane in the view.
When you look at an elevation view, where is the dwg in relation to the view plane?
2) The view is set to not display imported graphics.
Type VG then look at the Imported Catagories tab of the Visibility/Graphic Overrides dialog box.
