Hi All, I'm writing an plugin to be executed as an externalcommand, and I'm running into a problem, below are the lines of code.
Dim fam As FamilySymbol = M_Doc.GetElement(obj.Id)
Dim comp As FamilyInstance = AdaptiveComponentInstanceUtils.CreateAdaptiveComponentInstance(M_Doc, fam)
m_doc is a valid current document
obj.id is a valid id for a familysymbol
when the code reaches the second line "dim comp..." it throws an exception "an internal error has occured"
Any idea as to why it would be happening? Any input would be greately appreciated.
Sorry that I don't know VB but I find starnge that if you write...
Why can't you directly cast obj to fam as FamilySymbol because now you are getting the element from document which actually you already have. Or is there some kind of logical error in your code?
With only these 2 lines, it is hard to tell what's wrong.
From the code itself, it is correct.
Maybe the famiy symbol you passed in is not eligible to create the adaptive component.
