Mindaugas,
> The problem is that i need to retriangulate surface when point was
modified
> or deleted. It take a bit of time so i don't want regenerate surface if
Don't forget the undo function!
You might want to investigate overriding the AcDbDatabaseReactor reactor;
class dBaseReactor : public AcDbDatabaseReactor
public:
virtual void objectUnAppended(const AcDbDatabase* dwg, const
AcDbObject* dbObj);
virtual void objectAppended(const AcDbDatabase *pDwg, const
AcDbObject *pDbObj);
virtual void objectModified(const AcDbDatabase *pDwg, const
virtual void objectErased(const AcDbDatabase *pDwg, const
AcDbObject *pDbObj, Adesk::Boolean erased);
virtual void objectOpenedForModify(const AcDbDatabase* dwg, const
AcDbObject* dbObj);
and check in theses functions for your object!
Regards Gary
www.drcauto.com
"Mindaugas Bliudzius" wrote in message
news:2F10160818A1FEC46F7D72432162A33F@in.WebX.maYIadrTaRb...
> Hi, thank's for reply,
modified
> someone just opened and closed that point. At first i removed kForWrite
> (because this call event) from my program where i'm cheking objects and
only
> if i realy need to change objetc i used upgeradeOpen(). But still some
other
> program can do that 😞
> The main reason why your replay is good, that now i know that there is no
> straight way to do that 🙂 It is good to know that when you doing
something
> that there is no easier way 🙂 And thank's one more time for your
> suggestions. I'll try to use them.
> "Justavian" wrote in message
> news:081E897285A91F8550B2AE63777F1EE6@in.WebX.maYIadrTaRb...
> > As far as i know, there's no way to directly find out if an object was
> > ACTUALLY modified. I've been struggling with this fact for a long time.
> In
> > my particular case, however, all i need to know is whether the object
has
> > been moved or not. For that i store a point in my custom object -
> > m_pntLastPosition. Everytime the objectModified( ) function gets fired,
i
> > check that variable. If my NEW point doesn't match the LAST one, then i
> > know the object has been moved. What's the specific property that you
> need
> > to be aware of?
> > Another possible solution that i considered was to override the
functions
> in
> > my custom object that correspond to the properties i'm concerned about.
> > What i mean by that is that if i need to know if an object gets moved, i
> can
> > override the TransfromBy() function, and toggle a m_bWasModified
boolean.
> > Then, when objectModified gets called, i can identify that some sort of
> > significant change was made.
> > news:EAB401FFD30640080421860B21AEFE90@in.WebX.maYIadrTaRb...
> > > Hi,
> > > How to chek is object modified, because objectModified() event occurs
> when
> > > object was opened, but it may be still the same 😞 I need only thows
> > objects
> > > witch let say coordinates changed (not just was opened and closed).
Any
> > > idea?
