Hey Everyone,
I'd like to make 'PDF' files from 'DWF' AutoCAD files.
Therefore, I referred the official "AutoCAD .NET Developer Guide".
It has a sample code below. I tried this code.
However, an error has occured at the last part of this code, "acPlEng.EndPlot(null);".
Error shows "Error:Invalid Input";
I drew just one simple circle, and then put "PlotCurrentLayout" command.
Here's sample code. Sorry to be lengthy.
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.PlottingServices;
[CommandMethod("PlotCurrentLayout")]
public static void PlotCurrentLayout()
// Get the current document and database, and start a transaction
Document acDoc = Application.DocumentManager.MdiActiveDocument;
Database acCurDb = acDoc.Database;
using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
// Reference the Layout Manager
LayoutManager acLayoutMgr;
acLayoutMgr = LayoutManager.Current;
// Get the current layout and output its name in the Command Line window
Layout acLayout;
acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout),
OpenMode.ForRead) as Layout;
// Get the PlotInfo from the layout
PlotInfo acPlInfo = new PlotInfo();
acPlInfo.Layout = acLayout.ObjectId;
// Get a copy of the PlotSettings from the layout
PlotSettings acPlSet = new PlotSettings(acLayout.ModelType);
acPlSet.CopyFrom(acLayout);
// Update the PlotSettings object
PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
// Set the plot type
acPlSetVdr.SetPlotType(acPlSet,
Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
// Set the plot scale
acPlSetVdr.SetUseStandardScale(acPlSet, true);
acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit);
// Center the plot
acPlSetVdr.SetPlotCentered(acPlSet, true);
// Set the plot device to use
acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWF6 ePlot.pc3",
"ANSI_A_(8.50_x_11.00_Inches)");
// Set the plot info as an override since it will
// not be saved back to the layout
acPlInfo.OverrideSettings = acPlSet;
// Validate the plot info
PlotInfoValidator acPlInfoVdr = new PlotInfoValidator();
acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
acPlInfoVdr.Validate(acPlInfo);
// Check to see if a plot is already in progress
if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
using (PlotEngine acPlEng = PlotFactory.CreatePublishEngine())
// Track the plot progress with a Progress dialog
PlotProgressDialog acPlProgDlg = new PlotProgressDialog(false,
1,
true);
using (acPlProgDlg)
// Define the status messages to display when plotting starts
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.DialogTitle,
"Plot Progress");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage,
"Cancel Job");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage,
"Cancel Sheet");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption,
"Sheet Set Progress");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption,
"Sheet Progress");
// Set the plot progress range
acPlProgDlg.LowerPlotProgressRange = 0;
acPlProgDlg.UpperPlotProgressRange = 100;
acPlProgDlg.PlotProgressPos = 0;
// Display the Progress dialog
acPlProgDlg.OnBeginPlot();
acPlProgDlg.IsVisible = true;
// Start to plot the layout
acPlEng.BeginPlot(acPlProgDlg, null);
// Define the plot output
acPlEng.BeginDocument(acPlInfo,
acDoc.Name,
null,
1,
true,
"c:\\myplot");
// Display information about the current plot
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.Status,
"Plotting: " + acDoc.Name + " - " +
acLayout.LayoutName);
// Set the sheet progress range
acPlProgDlg.OnBeginSheet();
acPlProgDlg.LowerSheetProgressRange = 0;
acPlProgDlg.UpperSheetProgressRange = 100;
acPlProgDlg.SheetProgressPos = 0;
// Plot the first sheet/layout
PlotPageInfo acPlPageInfo = new PlotPageInfo();
acPlEng.BeginPage(acPlPageInfo,
acPlInfo,
true,
null);
acPlEng.BeginGenerateGraphics(null);
acPlEng.EndGenerateGraphics(null);
// Finish plotting the sheet/layout
acPlEng.EndPage(null);
acPlProgDlg.SheetProgressPos = 100;
acPlProgDlg.OnEndSheet();
// Finish plotting the document
acPlEng.EndDocument(null);
// Finish the plot
acPlProgDlg.PlotProgressPos = 100;
acPlProgDlg.OnEndPlot();
acPlEng.EndPlot(null); // <--- "Error:Invalid Input" occurs.
I'm developing with Visual Studio 2010 (C#) and Object ARX.
Any advice would be greatly appreciated.
this is happening here because, none of the actual plot processing is taking place until you call end plot. Then it reads all theinput data you fed it and has a cow with something. I've run into this way back in VBA. Check all the parameters you feed into it. It could be bad file name, bad printer name, bad location, bad layout name. Something of the like.
jvj
Hi, JamieVJohnson2.
Thank you for your answering.
I struggled to resolve this prob, so I reffered other sample codes in this web site.
Here is it's link.
http://through-the-interface.typepad.com/through_the_interface/
famaous site for developing applications regarding AutoCAD with Object ARX.
Thanks a lot.
