Hello
I have some code in a VBA program I'm trying to convert to .net that loops through all the entities in model space as in the code snip below. What I can't figure out is how to get the total number of objects in model space at the start so I can use this info to advance a progress bar. ie the equivilent of VBA's "ThisDrawing.ModelSpace.Count"
Thanks for any help
Dim bt As BlockTable = tr.GetObject(DB.BlockTableId(), OpenMode.ForRead) Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead) ' Loop for each entity in the modelspace For Each entId As ObjectId In btr '<code sniped> 'advance progress bar Next
there is no equivalent in dotNET for a BlockTableRecord, so you can enumerate through it (is that a correct english?) ... let's say scan through the BlockTableRecord to count it; or you have also access to the COM-based functions also in dotNET. As long as you don't access it to often within one function it will also be about no time-delay problem.
Here you have 3 versions, it you use 1 or 2 you have to add the references for COM-objects:
Autodesk.AutoCAD.Interop
Autodesk.AutoCAD.Interop.Common
Plus on top of the vb-file you need (for running the code below:
Imports Autodesk.AutoCAD
<Runtime.CommandMethod("ADESK_CountModelSpace1")> _ Public Shared Sub ADESK_CountModelSpace1() 'using Document as COM-object Dim tAcadDoc As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim tAcadDocCOM As Interop.AcadDocument = CType(tAcadDoc.AcadDocument, Interop.AcadDocument) MsgBox(tAcadDocCOM.ModelSpace.Count.ToString) End Sub <Runtime.CommandMethod("ADESK_CountModelSpace2")> _ Public Shared Sub ADESK_CountModelSpace2() 'using Modelspace-BlockTableRecord as COM-object Dim tAcadDoc As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim tTrAct As DatabaseServices.Transaction = Nothing Try tTrAct = tAcadDoc.TransactionManager.StartTransaction Dim tBlTab As DatabaseServices.BlockTable = CType(tTrAct.GetObject(tAcadDoc.Database.BlockTableId, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTable) Dim tModSp As DatabaseServices.BlockTableRecord = CType(tTrAct.GetObject(tBlTab(DatabaseServices.BlockTableRecord.ModelSpace), DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTableRecord) 'using the BlockTableRecord as COM-object Dim tModSpCOM As Interop.Common.AcadModelSpace = CType(tModSp.AcadObject, Interop.Common.AcadModelSpace) MsgBox(tModSpCOM.Count.ToString) Catch ex As Exception MsgBox("Some exception occured" & vbNewLine & ex.Message) Finally If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing End Try End Sub <Runtime.CommandMethod("ADESK_CountModelSpace3")> _ Public Shared Sub ADESK_CountModelSpace3() 'counting by scan Dim tAcadDoc As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim tTrAct As DatabaseServices.Transaction = Nothing Try tTrAct = tAcadDoc.TransactionManager.StartTransaction Dim tBlTab As DatabaseServices.BlockTable = CType(tTrAct.GetObject(tAcadDoc.Database.BlockTableId, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTable) Dim tModSp As DatabaseServices.BlockTableRecord = CType(tTrAct.GetObject(tBlTab(DatabaseServices.BlockTableRecord.ModelSpace), DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTableRecord) Dim tEnum As DatabaseServices.BlockTableRecordEnumerator = tModSp.GetEnumerator Dim tCounter As Integer = 0 Do While tEnum.MoveNext tCounter += 1 Loop MsgBox(tCounter.ToString) Catch ex As Exception MsgBox("Some exception occured" & vbNewLine & ex.Message) Finally If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing End Try End Sub
HTH, - alfred -
hi David,
As you are using VB.NET, you can implicit call the AcadObject using LateBinding:
Dim count as Integer = btr.AcadObject.Count
Hope this help.
Augusto Goncalves
Autodesk Developer Network
This did not work for me. Visual studio is suggesting that the "operator '>' cannot be applied to operands of type 'method group' and 'int'. below is the relevant ode.
BlockTableRecord btrLayout = tr.GetObject(bt[BlockTableRecord.PaperSpace], OpenMode.ForRead) as BlockTableRecord; if (btrLayout.AcadObject.Count > 0) { }
