How can I dwg file in the excel file in c # winform transfer?
Good Times
Sorry for translation
new post:http://forums.autodesk.com/t5/NET/reading-some-variables-into-DWG-file-how-C/m-p/3905039
Ok, that make a sence,
then try this code, but change before Excel file name,
shhet name and range address:
Require references to: Microsoft Excel 12.0 Object Library and Microsoft Office 12.0 Object Library //--------------------------------------------// #region "Imports" using System; using System.Collections.Generic; using System.Text; using Microsoft.Office.Interop.Excel; using Excel = Microsoft.Office.Interop.Excel; using System.Windows.Forms; #endregion public static void ReadExcel() { // set file name to read: string xlFileName = @"c:\Test\dummy.xls"; Excel.Application xlApp; Excel.Workbook xlBook; Excel.Sheets xlSheets; Excel.Worksheet xlSheet; Excel.Range xlRange; // get Excel application xlApp = new Excel.Application(); xlApp.Visible = false; object miss = Type.Missing; StringBuilder sb = new StringBuilder(); try { // try open workbook as read-only xlApp.Workbooks.Open(xlFileName, false, true, miss, miss, miss, miss, miss, miss, miss, miss, miss, miss, miss, miss); xlBook = xlApp.ActiveWorkbook; xlBook.Saved = true; xlApp.DisplayAlerts = false; xlSheets = xlBook.Worksheets; // few ways to get an Excel sheet // get sheet by name: // xlSheet = (Excel.Worksheet)xlSheets.Item["Big Sheet"]; // get sheet by index: xlSheet = (Excel.Worksheet)xlSheets.Item[1]; // get sheet by name: // xlSheet = (Excel.Worksheet)xlSheets.get_Item("Big Sheet"); // get sheet by index: // xlSheet = (Excel.Worksheet)xlSheets.get_Item(1); // few ways to get an Excel range // xlRange = (Excel.Range)xlSheet.Range[xlSheet.Cells[1, 1], xlSheet.Cells[5, 6]]; // the same as: xlRange = (Excel.Range)xlSheet.Range["A1:F5"];// <-- change range address here // read the whole range: //object[,] varr = (object[,])xlRange.Value2; // the same as: object[,] varr = (object[,])xlRange.Value; // get sizes of arrary: int i = varr.GetUpperBound(0); int j = varr.GetUpperBound(1); // loop thru array for (int a = 0; a < i; a++) { Excel.Range xlCell; string cell = ""; for (int b = 0; b < j; b++) { //cell index in Excel is non zero-based and starts from 1 xlCell = (Excel.Range)xlRange.Item[a + 1, b + 1]; cell = cell + xlCell.Value.ToString() + "\t"; } // populate stringbuilder sb.AppendLine(cell); } } catch (System.Exception ex) { MessageBox.Show(ex.Message); } finally { // close all workbooks xlApp.Workbooks.Close(); // quit application xlApp.Quit(); MessageBox.Show(sb.ToString()); } }
I have replied to your other post on this topic. The code snippet that I have posted is very minimal and you can get more details on using the Excel API from code snippet that Hallex has shared.
