changing drawing
changing drawing
Message 1 of 10
changing drawing
I use the handler DocumentBecameCurrent to detect a switching of drawings. When I try to use the database to check for non existing layers I got an fatal error.
I use the following code:
On load of the dll the handler is loaded:
Public Sub Initialize() Implements IExtensionApplication.Initialize
AddHandler Application, AddressOf SwitchStart
End Sub
At drawing switch the following handler is executed. The error occurs in Layers = New LayerManager
Here the layers are checked and if the do not exist created.
Public Sub SwitchStart(ByVal Sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventArgs)
' Make reference to drawing / Database
ed = e.Document.Editor 'Application.DocumentManager.MdiActiveDocument.Editor
db = e.Document.Database 'HostApplicationServices.WorkingDatabase
' Make a new Layermanager
Layers.DetectTrackLayers()
End Sub
Has any one a clue off the error?
Greetings,
Gerard van der Sel.
Replies (9)
Message 2 of 10
You should't expect to get help with a problem if you don't post the code where the problem is occuring.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5857105@discussion.autodesk.com...
End Sub
End Sub
Greetings,
Gerard van der Sel.
Message 3 of 10
You are right. Here is the code with the error:
Private Function CreateLayer(ByVal strucNewLayer As LayerStruc) As ObjectId 'identiek aan 'Private Function CheckLayer(ByVal newLayer As LayerStruc) As ObjectId
'the return value for this function
Dim layerId As ObjectId
Using tr As Transaction = db.TransactionManager.StartTransaction()
Try
'Controleren of de laag al bestaat ...
If LayerExists(strucNewLayer.Name) Then
'Eerst de layertable ophalen en openen voor lezen
Dim lt As LayerTable = DirectCast(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
'Ophalen laag
layerId = GetLayer(strucNewLayer.Name)
Dim ltr As LayerTableRecord = DirectCast(tr.GetObject(layerId, OpenMode.ForWrite), LayerTableRecord)
'laagkleur instellen
ltr.Color = Color.FromColorIndex(ColorMethod.ByLayer, strucNewLayer.col.ColorIndex) '/strucNewLayer.col
'linetype er aan koppelen
ltr.LinetypeObjectId = GetLineTypeId(strucNewLayer.LineType)
'visible instellen
ltr.IsOff = Not (strucNewLayer.Visible)
'isPlottable instellen
ltr.IsPlottable = strucNewLayer.IsPlottable
'Locked instellen
ltr.IsLocked = strucNewLayer.IsLocked
'Frozen instellen
ltr.IsFrozen = False
Else
'Laag aanmaken
Dim ltr As LayerTableRecord = New LayerTableRecord()
'laagnaam instellen
ltr.Name = strucNewLayer.Name
'visible instellen
'Locked instellen
'Frozen instellen
'laag toevoegen
Dim lt As LayerTable = DirectCast(tr.GetObject(db.LayerTableId, OpenMode.ForWrite), LayerTable)
layerId = lt.Add(ltr)
tr.AddNewlyCreatedDBObject(ltr, True)
tr.Commit()
Catch ex As Exception
tr.Dispose()
layerId = Nothing
End Try
End Using
'laagId teruggeven
Return layerId
End Function
The code itself is working, when executed from an other place. In this case this function gives the error in the statement:
The reported error is "locked database".
The switching of the database in the handler doesn't go well.
Greetings,
Gerard van der Sel
Message 4 of 10
In general, I don't think it is possible to do what you are trying to do from the DocumentBecameCurrent handler.
The reason is because the handler can fire at any time, including when there is something happening in the document that is being made current. For example, a command may be in progress, and the document could be locked and not accessable at that point.
If you would care to describe more generally, your need (e.g., why you need to create layers at that point), perhaps we can suggest another approach, but I very much doubt that the one you're pursuing is going to work.
wrote in message news:5857134@discussion.autodesk.com...
Try
'Ophalen laag
'visible instellen
'Locked instellen
'Frozen instellen
Else
'Laag aanmaken
'laagnaam instellen
'visible instellen
'Locked instellen
'Frozen instellen
'laag toevoegen
tr.Commit()
tr.Dispose()
layerId = Nothing
End Try
End Using
'laagId teruggeven
Return layerId
End Function
Greetings,
Gerard van der Sel
Message 5 of 10
Hi Selg,
Maybe you'll have better luck with the "documentActivated" event.
I use the documentActivated to retrieve the various styles and blocks of a drawing.
You should consider creating a class to manage the MDI.
and create You're own pre-document class.
I believe in the help sections of the ObjectARX SDK there some tips to consider.
ps. looking at you're first post: I think you're AddHandler is wrong: shouldn't it be:
AddHandler Application.DocumentManager.DocumentBecameCurrent, AddressOf SwitchStart ????
A. Caddie.
AutoCAD2008, VS2005, WinXP pro sp2.
Message 6 of 10
No, actually he'll have worse luck with that.
wrote in message news:5857622@discussion.autodesk.com...
Hi Selg,
A. Caddie.
Message 7 of 10
Process description:
I have started a dot net program with drawing1. When I load a new drawing2 I need to check if some default layers are present. If they are not present i need to create them. The layers must be present, because the block i have to insert rely on those layers.
In the "documentbecamecurrent" event is fired at all the situations i want to catch.
Greetings,
Gerard van der Sel
Message 8 of 10
Depends on wath you imports:
"Imports Autodesk.AutoCAD.ApplicationServices.Application" then you don't need Application.
"Imports Autodesk.AutoCAD.ApplicationServices" you need the application first.
Message 9 of 10
Is your code inserting the block?
If it is, why not create the layers just before you insert the block you have to insert?
wrote in message news:5858189@discussion.autodesk.com...
Greetings,
Gerard van der Sel
Message 10 of 10
The code is inserting the blocks. So making the layers while inserting the blocks is an option. But in our firm all layers are made. At the end is looked if a layer is empty and then removed.
I reconsidered what I want. And I noticed I have made an error. If I switch to a drawing it doesn't have to be this sort of drawing. It could be an other type, in which case the wrong layers are inserted. So only switching of database and editor is enough. This is working, so now only for my own understanding of AutoCAD it is necessary to know what went wrong.
Greetings,
Gerard.
