I did as per your suggestion..I get the following error...
Thanks for your advice..
System.InvalidOperationException: Operation is not valid due to the current state of the object.
at Autodesk.AutoCAD.Runtime.DisposableWrapper.Attach(IntPtr unmanagedPointer, Boolean autoDelete)
at Autodesk.AutoCAD.DatabaseServices.XrefGraph.GetXrefNode(Int32 idx)
at Xref.MyCommands.detach_xref() in C:\Users\Administrator\documents\visual studio 2010\Projects\Xref\Xref\myCommands.cs:line 419
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
code follows
[CommandMethod("Dref")]
public void detach_xref()
//get the document
Document Doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = Doc.Editor;
// Ask the user to select a folder
PromptResult res = ed.GetString("\nEnter the path of the folder: ");
string[] filepaths = Directory.GetFiles(res.StringResult, "*.dwg", SearchOption.AllDirectories);
int filecount = filepaths.Length;
ed.WriteMessage("\nScanning " + filecount + " files");
for (int i = 0; i < filecount; i++)
ed.WriteMessage("\n File Name : " + filepaths[i]);
//create a database and try to load the file
Database db = new Database(false, true);
using (db)
try
db.ReadDwgFile(filepaths[i], System.IO.FileShare.Read, false, "");
catch (System.Exception)
ed.WriteMessage("\nUnable to read the drawingfile.");
return;
db.ResolveXrefs(true, false);
using (Transaction tr = db.TransactionManager.StartTransaction())
XrefGraph xg = db.GetHostDwgXrefGraph(true);
int xrefcount = xg.NumNodes - 1;
ObjectIdCollection ids = new ObjectIdCollection();
XrefGraphNode xrNode = xg.GetXrefNode(i);
if(xrefcount > 0)
ObjectIdCollection btcoll = new ObjectIdCollection();
for (int j = 1; i < xrefcount; i++)
XrefGraphNode xrNode1 = xg.GetXrefNode(j);
if (xrNode1.XrefStatus == XrefStatus.FileNotFound)
//BlockTableRecord btr = (BlockTableRecord)tr.GetObject(xrNode1.BlockTableRecordId, OpenMode.ForWrite);
db.XrefEditEnabled = true;
ObjectId detachid = xrNode1.BlockTableRecordId;
db.DetachXref(detachid);
ed.WriteMessage("\nDetached successfully");
//transaction
tr.Commit();
There are several coding issues with your code. Check the index "for(j=1;i<xrefcount;i++)". Do you intend to increment i or j. You may need to clean-up the code.
Here is a sample code to detach Xref from a drawing. This might help you get started. Only the direct external references (not Nested Xrefs) will get detached using this if they are not found.
[CommandMethod("DetachXref")] public void detach_xref() { Document Doc = Application.DocumentManager.MdiActiveDocument; Editor ed = Doc.Editor; string mainDrawingFile = @"C:\Temp\Test.dwg"; Database db = new Database(false, false); using (db) { try { db.ReadDwgFile(mainDrawingFile, System.IO.FileShare.ReadWrite, false, ""); } catch (System.Exception) { ed.WriteMessage("\nUnable to read the drawingfile."); return; } bool saveRequired = false; db.ResolveXrefs(true, false); using (Transaction tr = db.TransactionManager.StartTransaction()) { XrefGraph xg = db.GetHostDwgXrefGraph(true); int xrefcount = xg.NumNodes; ObjectIdCollection ids = new ObjectIdCollection(); ObjectIdCollection btcoll = new ObjectIdCollection(); for (int j = 0; j < xrefcount; j++) { XrefGraphNode xrNode = xg.GetXrefNode(j); String nodeName = xrNode.Name; if (xrNode.XrefStatus == XrefStatus.FileNotFound) { ObjectId detachid = xrNode.BlockTableRecordId; db.DetachXref(detachid); saveRequired = true; ed.WriteMessage("\nDetached successfully"); break; } } tr.Commit(); } if(saveRequired) db.SaveAs(mainDrawingFile, DwgVersion.Current); } }
