You shouldn't be passing variables around, because
that requires them to be updated when they change
(e.g., passed to the other environment again).
Doing that makes no sense, and it is a basic design
flaw. In other words, you don't have to pass variables
to LISP, you should instead expose the .NET variable
as a Property of an ActiveX object that can be read
from LISP.
Whenever your LISP code needs to use the variable,
it just reads it from the ActiveX object's property,
which means that there only needs to be one copy
of the underlying data, rather than two that must
be kept synchronized.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Dale Levesque" wrote in message news:5021497@discussion.autodesk.com...
The variable is a counter to determine how many vertical dimensions have
been drawn so that it knows how far offset the current dimension should be
drawn. I can pass it to the .Net app but I want the .Net app to increment it
as it creates dimensions. That way Lisp will know the proper value after it
has been changed by the .Net app. Is it possible to pass a var created by
the lisp routine back after it has been modified in the .Net app?
Dale
"Tony Tanzillo" wrote in message
news:5015767@discussion.autodesk.com...
SendStringToExecute() is a member of the Document class.
However, the question that begs an answer is why
do you want to set LISP variables from .NET apps?
Wouldn't it be better to expose the variable in the
NET app via COM, so that when whatever LISP code
uses it, you can be sure that it will always get the
current value?
news:5015164@discussion.autodesk.com...
Is there something that I can use in VB .Net to accomplish the same as
SendStringToExecute in ObjectARX. All I really want to do is set a lisp
variable from a .net class library.
Dale
