ObjectARX SDK
ObjectARX SDK
Amremad
ObjectARX SDK
Amremad
Which ObjectARX SDK can i use to start
ObjectARX 2011
ObjectARX 2012
ObjectARX 2013
and what 's the diffrent between its?
and when i send dll that i did to my firend he must install ObjectARX?
or what can i do to solve the Autocad objectARX problem files??
hgasty1001
Use the ARX SDK with the same name as the AutoCAD version that the appliaction will  run on. Also check the .NET framework supported by the AutoCAD version:
AutoCAD 2011, ARX SDK 2011, .Net 2.0 or 3.5
AutoCAD 2012, ARX SDK 2012, .Net 4.0
AutoCAD 2013, ARX SDK 2013, .Net 4.0
You don't need to install the SDK in the machine intended to run the application, only the files specific to the application need to be in the machine
Gaston Nunez.
