As you can see in the attached print screen TheProblen.png I need to modify the XRecord within a file header sub directories.
I have managed to loop through the file directories and sub-directories and even extracted the ResultBuffer of the correct sub-directory.
I now have a ResultBuffer/XRecord that has an array of typed values in it and I need to modify one of the typed values.
How do I do it?
Thanks in advance,
David.
I've could not upload my *.vb file so here is my code.
Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Geometry 'Imports Autodesk.AutoCAD.Interop Imports Autodesk.AutoCAD.Colors Imports System Imports System.Collections.Specialized Public Class BentleyXDAta <CommandMethod("TEST", CommandFlags.UsePickSet)> Public Sub TEST() '' Get the current document editor Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Dim NOD As DBDictionary = acTrans.GetObject(HostApplicationServices.WorkingDatabase.NamedObjectsDictionaryId, OpenMode.ForRead) If NOD.Contains("AT_REBIS_APP") Then For Each NODEnt As DBDictionaryEntry In NOD If NODEnt.Key.ToString = "AT_REBIS_APP" Then Dim RebDB As DBDictionary = acTrans.GetObject(NODEnt.Value, OpenMode.ForRead) If RebDB.Contains("AT_REBIS_APP_DB") Then For Each RebDBEnt As DBDictionaryEntry In RebDB If RebDBEnt.Key.ToString = "AT_REBIS_APP_DB" Then Dim oXrecord As Xrecord = acTrans.GetObject(RebDBEnt.m_value, OpenMode.ForRead, False) Dim oResultBuffer As ResultBuffer = oXrecord.Data Dim oResultBufferArray As TypedValue() = oResultBuffer.AsArray Dim FlagNext As Boolean = False For Each Result As TypedValue In oResultBufferArray If FlagNext = True Then Beep() FlagNext = False End If If Result.TypeCode = 1 Then If Result.Value = "AT_REBIS_APP_DB_DOCTAGID" Then FlagNext = True End If End If Next 'Dim RebAppDB As DBDictionary = acTrans.GetObject(RebDB.ExtensionDictionary, OpenMode.ForRead) ''Dim RebAppDB As DBDictionary = acTrans.GetObject(RebDBEnt.Value, OpenMode.ForRead) ''For Each RebAppDBEnt As DBDictionaryEntry In RebAppDB '' acDocEd.WriteMessage("Rebis RebAppDBKey: " + RebAppDBEnt.Key.ToString + vbCrLf) ''Next End If acDocEd.WriteMessage("RebDBEnt Key: " + RebDBEnt.Key.ToString + vbCrLf) Next End If End If acDocEd.WriteMessage("NODEnt Key: " + NODEnt.Key.ToString + vbCrLf) Next End If End Using End Sub End Class
