.NET
Memory Stream and XRecords
5 REPLIES 5
889 Views, 5 Replies
Hello everybody,
I try to serilize a class with a binaryserialization and attach it as an xrecord to an entity using the memory stream. But I get an error occurred, when I try to run my test1 command (Cannot convert from MemoryStream into Byte[] Array). Here's the code:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Colors;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Diagnostics;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.Drawing;
using System.IO;
using Autodesk.AutoCAD.Windows;
using System.Runtime.Serialization.Formatters.Binary;
using System.Runtime.Serialization;
using System.Drawing.Imaging;
using Autodesk.Windows;
using System.Data;
using Autodesk.AutoCAD.ApplicationServices.Core;
[Serializable]
public enum DogColor
Brown,
Black,
Mottled
[Serializable]
public class Dog
public String Name
get;
set;
public DogColor Color
get;
set;
public override String ToString()
return String.Format("Dog: {0}/{1}", Name, Color);
[CommandMethod("TEST1")]
public void Test1()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptEntityOptions peo = new PromptEntityOptions("\nSelect an entity: ");
peo.AllowNone = false;
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status == PromptStatus.OK)
ObjectId id = per.ObjectId;
Dog myDog = new Dog();
myDog.Name = "Foo";
myDog.Color = DogColor.Brown;
ResultBuffer resbuf = new ResultBuffer();
MemoryStream memorystream = new MemoryStream();
BinaryFormatter bf = new BinaryFormatter();
bf.Serialize(memorystream, myDog);
resbuf.Add(new TypedValue((int)DxfCode.BinaryChunk, memorystream));
SetXrecord(id, "test", resbuf);
5 REPLIES 5
Matti72
The MemoryStream has a method ToArray which converts it to a Byte[]...
So change your line to
resbuf.Add(new TypedValue((int)DxfCode.BinaryChunk, memorystream.ToArray()));
 And the error will go away.
Alexander.Rivilis
As far as I remember BinaryChunk length have to be less than 255. So you have to split binary.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
in reply to: Matti72
thx, it works
in reply to: Alexander.Rivilis
I dont know, if it is really so.
I do the following changes:
string Mystring = "Lorem ipsum dolor sit ametor sit amet, consectetur adipiscing elit. Pellentesque quis tristique risus. Vivamus dignissim lacinia ante, eu pretium lacus congue eu. Pellentesque in pellentesque eros. Phasellus volutpat viverra erat vel ultrices. Praesent mattis metus.Lorem ipsum dolor sit ametor sit amet, consectetur adipiscing elit. Pellentesque quis tristique risus. Vivamus dignissim lacinia ante, eu pretium lacus congue eu. Pellentesque in pellentesque eros. Phasellus volutpat viverra erat vel ultrices. Praesent mattis metus.";
bf.Serialize(memorystream, Mystring);
Than I attach it, and it works.
I cannot get the byte array to be shown:
Autodesk.AutoCAD.ApplicationServices.Core.Application.ShowAlertDialog("The attached data is: " + memorystream.GetBuffer());
this code doesn't work.
How I have to do the splitting?
Matti72
If you serialize data you have to deserialize it, before you can use it again...
memorystream.Seek(0, System.IO.SeekOrigin.Begin);
string myStr = bf.Deserialize(memorystream) as string;
Autodesk.AutoCAD.ApplicationServices.Core.Application.ShowAlertDialog("The attached data is: " + myStr);
 edit:
In the line
you have (of course) to use the serialized class. So it is string in the example in your last post, in the example in your first post it would be
Dog myDog = bf.Deserialize(memorystream) as Dog;
And as always it would be a good idea to test the result, if it is null
Forma Design Contest
