.NET
Get current layer state
5 REPLIES 5
921 Views, 5 Replies
Can anyone point me in the right direction as to how to obtain the current layer state?
Thanks!
5 REPLIES 5
norman.yuan
Lokk into Autodesk.AutoCAD.DatabaseServices.LayerStateManager class.
Norman Yuan
Drive CAD With Code
philippe.leefsma
Hi
Here is a short sample:
private void updateLayerLock()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    LayerStateManager layStateMng = db.LayerStateManager;
    layStateMng.SaveLayerState("ColorLinetype", LayerStateMasks.Color & LayerStateMasks.LineType, ObjectId.Null);
    layStateMng.RestoreLayerState("ColorLinetype", ObjectId.Null, 1, LayerStateMasks.Color & LayerStateMasks.LineType);
    layStateMng.DeleteLayerState("ColorLinetype");
    ed.Regen();
Philippe
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
BlackBox_
Thanks!
To answer the specific question being asked, the LayerStateManager Class does not implement a Current Property as you're requesting, however, it (the LayerStateManager Class) does provide a LastRestoredLayerState Property.
Hope this helps - Cheers
"How we think determines what we do, and what we do determines what we get."
That helps.  Thank you!
BlackBox_
You're welcome; I'm happy to help.
Cheers :beer:
P.S. - Don't forget to mark the appropriate post as solution.
Forma Design Contest
