.NET
Excel to AutoCAD Table
15 REPLIES 15
Message 1 of 16
1401 Views, 15 Replies
I am having problems inputting excel info into an AutoCAD table. The code
below works great with small amounts of info but when I have more the 520
(just an example # I have been using) excel cells to go through When
inputting into the AutoCAD Table takes a very long time. Any ideas how to
speed this up? Below is my code:
Dim MyExcel As Excel.Application
Dim InsPt(0 To 2) As Double
Dim MyExcelApp As New Excel.Application
Dim MyExcelWB As Excel.Workbook
Dim MyExcelS As Excel.Worksheet
Dim intRows As Integer
Dim intCols As Integer
Dim i As Long
Set MyExcelWB = MyExcelApp.Workbooks.Open(MyPath & "\" & MyFile)
Set MyExcelS = MyExcelWB.Sheets(1)
intRows = MyExcelS.UsedRange.Rows.Count - 4
intCols = MyExcelS.UsedRange.Columns.Count
Set myTable = ThisDrawing.ModelSpace.AddTable(InsPt, intRows, intCols,
1, 1)
myTable.HeaderSuppressed = True
myTable.TitleSuppressed = True
For Y = 1 To intRows
pb1.Value = pb1.Value + 1
'go through each column in the table
For X = 1 To intCols
myTable.SetCellAlignment Y - 1, X - 1, acMiddleCenter
myTable.SetCellTextHeight Y - 1, X - 1, "7.5"
'Find the text in the cell of Excel
'This next line is the line that takes forever to complete.
myTable.SetText Y - 1, X - 1, UCase(MyExcelS.Cells(Y + 4,
X).Text)
Next X
Next Y
15 REPLIES 15
Message 2 of 16
Nate Hunter wrote:
> ... into the AutoCAD Table takes a very long time. Any ideas how to
> speed this up?
If AutoCAD Version > 2005 then set the RegenerateTableSuppressed.
Terry
Message 3 of 16
The slowness is expected when you have to garb a few hundreds of value by
looping through cells in Excel sheet, using auotmation, For each value, the
communication has to pass through 2 applications' (ACAD and Excel) process
boundary. Not to mention the added layer of .NET Interop. Also, populating
AcadTable object itself in Acad is quite heavy process.
In your case, at least you can improve reading data from Excel part
significantly by using ADO/DAO/ADO.NET to read needed data into Acad in one
shot. Basically you can use MS Jet Oledb provider to open a ADO/DAO
RecordSet/ADO.NET DataSet/DataTable/Array, and then populate the Acad table.
"Nate Hunter" wrote in message
news:5101549@discussion.autodesk.com...
Dim i As Long
1, 1)
X).Text)
Next X
Next Y
Message 4 of 16
how do I do that? Mytable.RegenerateTableSuppressed = True????
"Terry W. Dotson" wrote in message
news:5101649@discussion.autodesk.com...
> speed this up?
Terry
Message 5 of 16
You are the man. this is exactly what I was looking for. My table no
inputs very quick. Thanks for your help
> speed this up?
Terry
Message 6 of 16
Norman Yuan wrote:
> ... you can improve reading data from Excel part
> significantly by using ADO/DAO/ADO.NET to read needed data ...
Agreed, assuming you don't need any other cell properties.
Terry
Message 7 of 16
Great advice. Do any of you have an example on how to do this? I am also
looking to change the cell background color. I tried:
Dim col As New AcadAcCmColor
col.SetRGB 173, 173, 173
myTable.SetCellBackgroundColor Y, X, col
but with no luck. I do not receive any errors but I also do not see any
color to my cells. Any Ideas??
news:5101720@discussion.autodesk.com...
Terry
Message 8 of 16
ADO/DAO is widely documented on the web.
Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.16")
My example works in VBA. There may be differences in .NET.
Terry
Message 9 of 16
I am also using VBA. Where do I place the color code? Maybe I am trying
to do the wrong thing. I am trying to get the cell background fill to color
253
Here is what I have and I get no color on my table.
For y = 1 To intRows
For x = 1 To intCols
myTable.RegenerateTableSuppressed = True
myTable.SetCellBackgroundColor y, x, col
myTable.SetText y - 1, x - 1, UCase(MyExcelS.Cells(y + 4, x).Text '
gets the line from excel and places in AutoCAD.
Next x
Next y
I really appreciate your help on this.
news:5102873@discussion.autodesk.com...
Terry
Message 10 of 16
I found the following book useful for learning ADO.NET.
http://www.microsoft.com/MSPress/books/4825.asp
I already had ADO experience but ADO.NET is completely different.
I would recommend you go straight for ADO.NET.
Regards - Nathan
Message 11 of 16
Then your posting in the wrong group!
Terry
Message 12 of 16
I realize I am posting in the wrong group. the program started out in .Net
but once I could only find someone who is writted in VBA I switched over for
example purposes. This is the only group that I have found any information
about working with tables. My intent is to move my code into .NET when I am
finished finding out what I need to do.
So any ideas what my problem may be?
news:5103098@discussion.autodesk.com...
Terry
Message 13 of 16
Mikko
Dim acadMoS As IAcadModelSpace2 = acadDoc.ModelSpace
Dim pt(2) As Double
pt(0) = 5.0
pt(1) = 5.0
pt(2) = 0.0
Dim MyTable As AcadTable
MyTable = acadMoS.AddTable(pt, 5, 5, 1, 2)
Dim cr As AcadAcCmColor
cr = AcadApp.GetInterfaceObject("AutoCad.AcCmColor.16")
cr.SetRGB(255, 255, 0)
MyTable.SetCellBackgroundColor(3, 2, cr)
MyTable.SetCellBackgroundColorNone(3, 2, False)
Message 14 of 16
Alright you got me on the right track. Thank you very much. I have one
last question for you. I am trying to fill every other line in my table.
How can I go through every other line and set a background fill to it. Here
is my code:
y = my row & x = my column
Set NewColor = New AcadAcCmColor
NewColor.SetRGB 173, 173, 173
myTable.SetCellBackgroundColor y - 1, x - 1, NewColor
If strOddEvenTable = "Even" Or strOddEvenTable = "" Then
myTable.SetBackgroundColorNone y - 1, True
strOddEvenTable = "Odd"
Else
myTable.SetBackgroundColorNone y - 1, False
wrote in message news:5104040@discussion.autodesk.com...
Dim pt(2) As Double
pt(0) = 5.0
pt(1) = 5.0
pt(2) = 0.0
Message 15 of 16
I am sorry I meant to say every other row. I am trying to fill the cell
background for every other row.
Any Ideas??
Thanks again for your help. Below is my code:
news:5104104@discussion.autodesk.com...
is my code:
Else
Dim pt(2) As Double
pt(0) = 5.0
pt(1) = 5.0
pt(2) = 0.0
Message 16 of 16
Can i knowhow to work out with this in .Net i think there is a lot of change can anyone help with me the basics how to draw a table so that i can try to make up for the other half..
Thanks in advance
Kamala
Forma Design Contest
