• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Determine 32- or 64-bit application
    536 Views, 7 Replies
    01-07-2013 07:31 AM
    I am using a dllimport from accore.dll, but the entry point for the method in the dll differs between 32-bit and 64-bit version of AutoCAD. How can I check whether the AutoCAD application is a 32- or 64-bit version, i.e. the dll is 32- or 64-bit?
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Determine 32- or 64-bit application
    01-07-2013 07:51 AM in reply to: Fredrik.Larsen
    public static bool IsX64()
       if (IntPtr.Size == 4) return false;
                 else        return true;
     Sample of using: http://forums.autodesk.com/t5/NET/Can-t-find-ModelessOperationWill-Start-Event-in-Dot-net/m-p/344769...
    Other example: http://forums.autodesk.com/t5/NET/Save-a-password-protected-drawing-without-password-with-VB-NET/m-p...
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    01-07-2013 08:42 AM in reply to: Alexander.Rivilis
    Hi Alexander,
       return IntPtr.Size == 8;
    is less verbose and quite self explanatory.
    Gilles Chanteau
    Moderator
    Alexander.Rivilis
    01-07-2013 01:37 PM in reply to: _gile
    Totally agree!
    Active Contributor
    01-08-2013 04:19 AM in reply to: Alexander.Rivilis
    Hi
    I didn't know about the IntPtr.size, so thank you for that information. But in my case I can't use this since I can't get IntPtr.size directly in a class where the dllimport is happening. You have to be whithin a method to use it.
    Instead I used conditional compilation symbols and I compile one dll for 32-bit and one for 64-bit. By using the conditional compilation symbols the correct part of the code is compiled for each build.
    Moderator
    Alexander.Rivilis
    01-08-2013 04:30 AM in reply to: Fredrik.Larsen
    Why? Did you watch the examples to which I referred?
    Active Contributor
    01-08-2013 04:33 AM in reply to: Alexander.Rivilis
    Yes, you're right. That might be easier leaving everything in one dll.
    Moderator
    Alexander.Rivilis
    01-08-2013 05:26 AM in reply to: Fredrik.Larsen
    Sample that demonstrate common source code for different AutoCAD version and Platform (32 or 64 bit):
    using System;
    using System.Runtime.InteropServices;
    using System.Windows.Forms;
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.ApplicationServices;
    using AcAp = Autodesk.AutoCAD.ApplicationServices;
    [assembly: CommandClass(typeof(Rivilis.HookESC))]
    namespace Rivilis
      public static class HookESC
        static int AcadVer = AcAp.Application.Version.Major;
        // For AutoCAD 2007 - 2012 64 bit
        [DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl,
          EntryPoint = "?acedRegisterFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")]
        private static extern int acedRegisterFilterWinMsg2012x64(WindowHookProc callBackFunc);
          EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")]
        private static extern int acedRemoveFilterWinMsg2012x64(WindowHookProc callBackFunc);
        // For AutoCAD 2007 - 2012 32 bit
          EntryPoint = "?acedRegisterFilterWinMsg@@YAHQ6AHPAUtagMSG@@@Z@Z")]
        private static extern int acedRegisterFilterWinMsg2012x32(WindowHookProc callBackFunc);
          EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPAUtagMSG@@@Z@Z")]
        private static extern int acedRemoveFilterWinMsg2012x32(WindowHookProc callBackFunc);
        // For AutoCAD 2013 64 bit
        [DllImport("accore.dll", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl,
        private static extern int acedRegisterFilterWinMsg2013x64(WindowHookProc callBackFunc);
        private static extern int acedRemoveFilterWinMsg2013x64(WindowHookProc callBackFunc);
        // For AutoCAD 2013 32 bit
        private static extern int acedRegisterFilterWinMsg2013x32(WindowHookProc callBackFunc);
        private static extern int acedRemoveFilterWinMsg2013x32(WindowHookProc callBackFunc);
        private static int acedRegisterFilterWinMsg(WindowHookProc callBackFunc)
          if (AcadVer >= 19) {
            if (IntPtr.Size == 4) return acedRegisterFilterWinMsg2013x32(callBackFunc);
                      else        return acedRegisterFilterWinMsg2013x64(callBackFunc);
          } else {
            if (IntPtr.Size == 4) return acedRegisterFilterWinMsg2012x32(callBackFunc);
                      else        return acedRegisterFilterWinMsg2012x64(callBackFunc);
        private static int acedRemoveFilterWinMsg(WindowHookProc callBackFunc)
            if (IntPtr.Size == 4) return acedRemoveFilterWinMsg2013x32(callBackFunc);
                     else         return acedRemoveFilterWinMsg2013x64(callBackFunc);
          else {
            if (IntPtr.Size == 4) return acedRemoveFilterWinMsg2012x32(callBackFunc);
                     else         return acedRemoveFilterWinMsg2012x64(callBackFunc);
        // hook message filter callback function
        [UnmanagedFunctionPointer(CallingConvention.Cdecl)]
        public delegate int WindowHookProc(ref Message msg);
        private static WindowHookProc callBackFunc = null;
        private static int WindowsHook(ref Message msg)
          if (msg.Msg == 0x0100 && msg.WParam == (IntPtr)0x1b) {
            // MessageBox.Show("ESC pressed"); // <- your's action
            // acedRemoveFilterWinMsg(callBackFunc); // <- unregister callback
          return 0;
        [CommandMethod("SetHookEsc")]
        public static void SetHookEsc()
          callBackFunc = new WindowHookProc(WindowsHook);
          acedRegisterFilterWinMsg(callBackFunc);
        [CommandMethod("UnsetHookEsc")]
        public static void UnsetHookEsc()
          if (callBackFunc != null) acedRemoveFilterWinMsg(callBackFunc);
