Problems :
I was trying copy objects using .clone or .copyfrom but i don't know how to copy objects without references between new and selected block.
My Code :
Dim acdoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acdoc.Database Dim acBt As BlockTable Dim acBtr As BlockTableRecord Dim E As Integer Dim newBtrId As ObjectId Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction acBt = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite) acBtr = acTrans.GetObject(acBt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) 'Let the user select Objects from drawing Dim acSSPrompt As PromptSelectionResult = acdoc.Editor.GetSelection() If acSSPrompt.Status = PromptStatus.OK Then Dim acSSet As SelectionSet = acSSPrompt.Value 'Paste position Dim myPoint As PromptPointResult = acdoc.Editor.GetPoint("Paste point: ") 'Read Selection Set For Each acSSObj As SelectedObject In acSSet 'Look for ObjectId of my Selected Object For Each acObjId As ObjectId In acBtr If acObjId = acSSObj.ObjectId Then 'Take selected object as Blockreference Dim Et As Entity = acTrans.GetObject(acObjId, OpenMode.ForWrite) If TypeOf Et Is BlockReference Then 'Current Block Selected Dim Br As BlockReference = Et 'Here I should Paste all objects from Br to BlkRef ... 'Create a new BlockTableRecord Dim blkRef As BlockTableRecord = New BlockTableRecord() blkRef.Name = "beta" & E + 1 'Add BlockTableRecord newBtrId = acBt.Add(blkRef) acTrans.AddNewlyCreatedDBObject(blkRef, True) 'Paint BlockReference Dim bob As New BlockReference(myPoint, newBtrId) acBtr.AppendEntity(bob) acTrans.AddNewlyCreatedDBObject(bob, True) E = E + 1 End If End If Next Next acTrans.Commit() End If End Using End Sub
Any idea will be apreciated !
Thank's a lot!
I would call the .Explode method on each of the selected blocks, then add the entities created by .Explode to the new BlockTableRecord.
'first declare a New DbObjectCollection
Dim ExpObjs as New DbObjectCollection()
'I would change this loop "For Each acSSObj As SelectedObject In acSSet" to ->
For Each AcObjId as ObjectId in acSSet.GetObjectIds
'And lose this loop altogether "For Each acObjId As ObjectId In acBtr"
Br.Explode(ExpObjs)
For Each dbo as DbObject in ExpObjs
blkref.AppendEntity(dbo)
acTrans.AddNewlyCreatedDbObject(dbo, True)
Next
Edit: I am slightly confused as to whether you intend to create 1 new block for each block selected, or 1 new block containing all blocks selected, and unfortunately the example as typed is a combination of the two. If you want a new block to be created for each of the blocks selected, then you should move the declaration of the New DbObjectCollection to inside the For Loop. If you want one new block containing all of the selected blocks, then you should move the new For Loop (for each dbo as DbObject in ExpObjs) and the new block insert to outside the main For Loop.
Thank's chief !
I would like one new block definition for each block selected,
I'm gonna try what you said thank you very very much !
I was trying your answer but i have an error on:
For Each dbo As DBObject In ExpObjs blkRef.AppendEntity(dbo) acTrans.AddNewlyCreatedDBObject(dbo, True) Next
Autodesk.AutoCAD.Runtime.Exception: eNotInDatabase Autodesk.AutoCAD.DatabaseServices.TransactionManager.AddNewlyCreatedDBObject(DBObject obj, Boolean add)
All code :
Public Sub Copy_Paste() Dim acdoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acdoc.Database Dim acBt As BlockTable Dim acBtr As BlockTableRecord Dim E As Integer Dim newBtrId As ObjectId Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction acBt = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite) acBtr = acTrans.GetObject(acBt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) Dim acSSPrompt As PromptSelectionResult = acdoc.Editor.GetSelection() If acSSPrompt.Status = PromptStatus.OK Then Dim acSSet As SelectionSet = acSSPrompt.Value For Each AcObjId As ObjectId In acSSet.GetObjectIds Dim Et As Entity = acTrans.GetObject(AcObjId, OpenMode.ForWrite) If TypeOf Et Is BlockReference Then Dim Br As BlockReference = Et Dim ExpObjs As New DBObjectCollection() Br.Explode(ExpObjs) Dim blkRef As BlockTableRecord = New BlockTableRecord() blkRef.Name = "beta" & E + 1 For Each dbo As DBObject In ExpObjs blkRef.AppendEntity(dbo) acTrans.AddNewlyCreatedDBObject(dbo, True) Next newBtrId = acBt.Add(blkRef) acTrans.AddNewlyCreatedDBObject(blkRef, True) E = E + 1 End If Next End If End Using End Sub
i don't know what i'm missing...
thank's !
you do create a BlockTableRecord (blkRef)
then you add objects into this blockdefinition and - now the error - the transaction should add an object to a blockreference, that is not known by the transaction.
So: after creating the BlockTableRecord ==> add this to the BlockTable and to the current transaction
After that (!) add objects to the BlockTableRecord.
So the code-snippet should look like:
Dim blkRef As BlockTableRecord = New BlockTableRecord() blkRef.Name = "beta" & E + 1 'now these two lines where moved upwards newBtrId = acBt.Add(blkRef) acTrans.AddNewlyCreatedDBObject(blkRef, True) For Each dbo As DBObject In ExpObjs blkRef.AppendEntity(dbo) acTrans.AddNewlyCreatedDBObject(dbo, True) Next
HTH, - alfred -
Thank's ! it works !!
I missed to copy all attributes to the new block , I tried doing as what i pasted here, but i think that's not the correct way to do it :
For Each atrib As ObjectId In Br.AttributeCollection Dim att As AttributeReference att = acTrans.GetObject(atrib, OpenMode.ForWrite) blkRef.AppendEntity(att) acTrans.AddNewlyCreatedDBObject(att, True) Next
How i could add into a blocktablerecord an Attribute ?
Sorry I missed that Paul, but yes, as you have discovered, the BlockTableRecord must be Database Resident before you start adding thins to it.
To be thorough, I should also mention that the Explode method will fail if the block is not Uniformly Scaled, just as the AutoCAD Explode command does.
As far as the attributes, You should open the BlockTableRecord of the BlockReference you are exploding, and create new AttributeReferences from the AttributeDefinitions in the BlockTableRecord.
To be honest, having to do that means you almost might as well just copy everything to your new block from there, and skip the Explode. I'll spend a few minutes working up a sample.
Why don't you just get the BlockTableRecord of the BlockReference and DeepClone it?
Frankly, I was trying to stick closer to his code and pick it up from there, but as I was just working on it, I realized that a deep clone would be easier, faster, and avoid the problem of non-uniformly scaled block references.
This was thrown together very quickly need error handling etc....
<CommandMethod("DeepCloneBlock")> _ Public Sub DeepCloneBlock() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Using trx As Transaction = db.TransactionManager.StartTransaction() Dim tvs() As TypedValue = {New TypedValue(0, "INSERT")} Dim selectionFilter As New SelectionFilter(tvs) Dim result As SelectionSet = ed.GetSelection(selectionFilter).Value Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForWrite) For Each objId As ObjectId In result.GetObjectIds Dim bref As BlockReference = trx.GetObject(objId, OpenMode.ForRead) Dim btr As BlockTableRecord = trx.GetObject(bref.BlockTableRecord, OpenMode.ForRead) If Not bt.Has(btr.Name & " Copy") Then Dim map As New IdMapping() Dim newBtr As BlockTableRecord = btr.DeepClone(bt, map, False) newBtr.Name = btr.Name & " Copy" bt.Add(newBtr) trx.AddNewlyCreatedDBObject(newBtr, True) End If Next trx.Commit() End Using End Sub
remarkably similar to what I just did, but needs one more thing (maybe). If you want to maintain the AttributeReference Values of the original BlockReference, then you'll need to gather them up into a collection for when you insert the new BlockReference.
that's truth chief, how i could do that chief ??
I was trying using that code but without success
For Each objId As ObjectId In btr Dim obj As Object obj = acTrans.GetObject(objId, OpenMode.ForWrite) If TypeOf obj Is AttributeDefinition Then Dim AttDef As AttributeDefinition = obj Dim AttRef As New AttributeReference AttRef.SetAttributeFromBlock(AttDef, bob.BlockTransform) End If Next
Since I don't really know how you plan on using this code, I'm guessing a little here, but I have an idea that would greatly simplify the process:
Do you intend to delete the originally selected block?
Do you intend to have the new block in the same location/orientation as the original block?
No, I only want to clone it, but without object references. solved.
I would like to have news blocks with the same orientation as the original but in a different selected point. solved.
My only problem now appears when i have clone it, if i create the blockreference by code i lose all attributes, but if i do it manually once i have clone it going to the insert option Autocad let me change all Attributes before insert it.
I would like to know what i have to do if i want to insert my attributes on my blockreference by code.
Essentially you have a unique situation where you can make the process much easier by cloning the original block reference to create your new reference.
Dim newBref As BlockReference Using MS As BlockTableRecord = acTrans.GetObject(Br.OwnerId, OpenMode.ForWrite, False, True) newBref = Br.Clone() newBref.BlockTableRecord = newBtrId MS.AppendEntity(newBref) acTrans.AddNewlyCreatedDBObject(newBref, True) End Using
That way all the attributes are brought over with the clone, then move newBref to the new desired location, however it is you are doing that.
I am confused,
I first read through it quickly and the code I posted did not make much sense, but what I thought you were after and wanted.
Maybe I jumped in too quick and added to my confusion.
I apologize as Chief was getting trying to figure out your problem and my post might of side track it a bit.
The code I posted really just takes up space because it is just a copy of a existing 'BlockDefinition'.
From your first post, Chief's first reply would be the answer.
Just trying to help figure out what you after.
Maybe rewording question and replacing the word 'Block' with BlockReference or BlockDefinition might help?
It's all good Jeff. While my first response is one approach that would have worked, the DeepClone idea made the code much simpler, and as I mentioned earlier in the thread, the Explode option has issues with non-uniformly scaled block references, which the DeepClone option handles just fine.
I personally struggle to see the value of this routine, but I choose not to dwell on the perceived usefulness, and just focus on the question instead. I figure he must have a purpose, even if that purpose is simply a learning experience.
I can't remeber off the top of my head but for some reason I was thinking that ExplodeToOwnerSpace worked with non-uniformly scaled block references.
I could be wrong.
In my code I have several blocks that are always scaled non-uniformly. I think there are reasons that I have not used ExplodeToOwnerSpace, but I will check some stuff out... I'll let you know
