I need to change arrowheads of dimension style to default value. I find out from AutoDesk Exchange document this list:
"" closed filled
"_DOT" dot
"_DOTSMALL" dot small
"_DOTBLANK" dot blank
"_ORIGIN" origin indicator
"_ORIGIN2" origin indicator 2
"_OPEN" open
But I can not use "" to change back to default. Please help. Thank you so much
I want to change dimension style. And DimStyleTableRecord didn't have SetDataBaseDefault() Method.
Try this DevBlog http://adndevblog.typepad.com/autocad/2012/11/setting-different-arrow-heads-for-dimension-style.html . This blog shows how to set the different arrow heads for dimension style.
