Is it possible to use Autocad object in program other then autocad for example Robot?
I'm trying to use elements like Polyline arc3d Vectors3d and Point3d?
I it is not possible to use autocad objects do you have some other classes that could be useful to get lenght at point or get angel between points?
acdbmgd.dll, acmgd.dll, accoremgd.dll can be using only with AutoCAD and it's vertical application (such as AutoCAD Architecture, Civil3D, Mechanical, etc.)
Vector3D and Point3D are a classes from System.Windows.Media.Media3D namespace (PresentationCore.dll)
Facebook | Twitter | LinkedIn
Thanks for explaining.
In my program I need to get several things:
Get distance along polyline in 3d to point in 3d.
Get center of an arc in 3d based on three subsequent vertex of polyline.
Get angle between subsequent points and center of above arc.
Get angle between three subsequent points.
Do you have some tips how to get those things or where to look for some assembly that could do that?
Would not like to build something that already is out there.
Frustrating is that I had this in autocad and it was so easy 😉
You can easily use these objects abilities in a separate dll and then implement them in any other environments
I had vacation, now I back to my proejct ;).
I was trying to use those functions in separate class but it didnt work could you show me some sample how shoould the dll look like? (For some sample object abilitie) or refer to some source?
Maciej_R wrote:
…I was trying to use those functions in separate class but it didnt work…
I have to repeat that it is impossible to use acdbmgd.dll, acmgd.dll, accoremgd.dll outside AutoCAD. So you'll have to create these classes / methods themselves.
