• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    GeoSchaap
    ArxWizards install problem
    400 Views, 5 Replies
    06-05-2011 08:16 AM
    I'm trying to install the ArxWizards, but keep on reciving this error attached. I'm working with autocad 2012 and visual studio 2010.
    any suggestion?
    Please use plain text.
    ADN Support Specialist
    Balaji_Ram
    Re: ArxWizards install problem
    06-05-2011 08:17 PM in reply to: GeoSchaap
    Can you please try setting the User Access Control Settings (UAC) to "Never Notify" and then start the ArxWizards installer ?
    A system restart may be required after the UAC setting is modified.
    Hope this helps.
    Cheers,
    Balaji
    Developer Technical Services
    Autodesk Developer Network
    Balaji
    GeoSchaap
    06-05-2011 10:58 PM in reply to: GeoSchaap
    hi Balaji,
    thanks for respond. Installation did work after I did what you said, so thanks. Now, I enter the Visual Studio starting a new project, but in the New Project dialog/Visual C# Projects there is no “AutoCAD Managed C# Project” template. :smileysad:
    Balaji_Ram
    06-05-2011 11:18 PM in reply to: GeoSchaap
    The AutoCAD .Net Wizard is different from the ObjectARX Wizard.
    You can get it from the Developer Center. Here is the link :
    AutoCAD .Net Wizard
    http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
    Cheers,
    Balaji
    Balaji
    GeoSchaap
    06-06-2011 12:09 AM in reply to: Balaji_Ram
    Balaji, you are tha man! It works! thanks...
    New Member
    04-01-2013 06:17 PM in reply to: Balaji_Ram
    thank,it is almost not been mention in chinese web site,you help me a lot.
